i have a client who uses google apps and his email address is user@hiscompanyname.netI would like to know how i can setup the voicemail notification to the above email address? Not sure what smtrp settings to put in there.I have set it up earlier whe...
My client received a call from their service provider (ATT) that they reported over 700 calls placed from Friday, spec to places in Cuba and Canada on their main line number!Would you know if I can access the call logs in some way to check what ext t...
Hi Guys,Down to my last two issues with my uc520 deployment.1) The redlight for messages, and the 7914 extension modules are showing messages when there are none. Even when running the WMI script to refresh the phones, it's still showing messages. An...
Hi,I am trying to change my Ata 186 from a IOS that handle SCCP to a image that can handle SIP-communitation.I have put the useTFTP to 0, and as you can see, tries to use the ata186us, to change the IOS. (See under) But, I only get "configuration fai...
I changed the data vlan to be 192.168.100.0 using the wizard. When it finished, I tried to connect and it does not accept the username and password I established with the wizard. How can I reset the user and password? Also, I tried cisco/cisco but...
If one of the spoke sites calls an extension of a user at the hub and tries to leave a voicemail, they get disconnected. I had them call the hub voicemail extension (500) and it rings busy. Does the spoke locations need the voicemail dial-peer a...
hello i dont know what happened all of sudden i turned the UC 520 off and when i turned on the fan keeps on running in speed and the VM light that use to glow before is dead and there is no power in Act Ehernet ports what should i do
Hi,Last night my uC520 for whatever reason crashed. All LED indicators came on and the fan was on high speed.I perfomed the normal power off and power on and cant get the device to boot.I conencted the console cable and this is what I see:System Boot...
Hi Guys,Looking for advice why I can not seem to upgrade to 7.1.3 EA using CCA2.1.1 I get receive the error message make sure FTP/ SFTP software is not running which it aint.The error log looks like:E Install in progress, please wait... (3)CUE Instal...
I do know that IPv6 is supported in the following:Cisco IOSCisco Unified CME 8.0 and laterCisco SA500 seriesCisco 7906, 7911, 7931, 7941G, 7941GE, 7961G, 7961GE, 7970G, 7971G, 7971G-GE, 7942, 7962, 7945, 7965, 7975 IP Phones with CME 8.0 and laterWil...
Trying to find a quick guide / summary of the user level menu options for CUE on a UC500. That is, what is the digit to delete, save, skip, etc when playing back messages at a user level. If anyone has a link, can you please provide it?
Is there a way to create a voicemail box that has a greeting with a zero out option, but does not allow a caller to leave a voicemail?Could I set the voicemail box capacity really really low so no one can leave a message?I don't want to set a simple ...
Hi,Is there anyone that can recommend a VOIP Adapter that works with franking machines? I have been told that the specification it has to meet, isasynchron/duplex 2400/2400 bit/s (V22)asynchron/duplex 1200/1200 bit/s (V22)asynchron/duplex 300/30...
Hi all ,I'm testing the configuration of cisco UC520 to try all the features, so now I'm testing the Extension mobility feature, any way I was able to configure it and every thing but when I need to login I need to go (services--Extension Mobility--...
