Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
in our school we have >10 WAP121-E-K9 V01 (fw 1.0.6.2)
Sometimes it happens that all associated clients to a related AP are no longer able to surf and new devices can't connect to the "freezed" AP. Only solution is reboot the AP.
It may depend on...
Just purchased two WAP571E to link to buildings together. I had the waps configured with wds at my office, turn off and installed at customer location and the WDS bridge will not link. I have reconfigured both, tried with encryption and without, ch...
I have bought wireless access points WAP351 and I am having problems connecting with my Android phone. The logs on the AP report the following
Feb 4,2016 16:50:29 err hostapd[1583] trying to deauthenticate to station aa:bb:cc:dd:ee:ff, but not authen...
Hello ,
I use 3 new Cisco WAP 351 but i have a lot of wifi issue ..
From some devices ( smartphone or Computer ) the devices are connected ... disconnected .. connected ... disconnected and some time i need to manually join the wifi ...
The 3 WAP...
Can anyone please confirm the system memory specs for WAP371 ? It looks like Cisco is providing worng information on their on website.
Data sheet reads 64/32 but 'compare' tool reads 256/128 RAM & Flash
Hello.
I have a very simple question regarding the aforementioned device which I know very well it's no longer being supported / EOL. Bear with me while I explain the situation:
Currently it has HTTPS enabled and works as intended. To my knowledge, t...
Hello all,Been using the WAP321, 2 of them in our home for quite some times but about once a week and today 3x after eachother i see this in the logs:Oct 25 2013 15:09:17infohostapd[2452]The wireless client with MAC address dc:85:de:48:a8:12 has been...
I get the message "Firmware upgrade has failed. Please ensure that valid entries were specified in the required fields." when I try upgrade the firmware,
I am not unpacking the .tar, I'm using it just as it is downloaded from cisco.com.
I have ...
I was told that the Surface Pro would run Cisco AnyConnect. I would like to know if anyone is using this on their Surface and if there were any issues in installing. I haven't yet tried to download it wanted to hear some opinions first.
I just have Setup one WLC 2504 with LAP AIR-AP2702I-UXK9
Now i have the following symptoms:
Led do not stop Flashing between red and green.
The LAP have successfully joined the Controller and i am able to connect to the SSID to ,- and i got the...
Hi Cisco Community
We have 2 x WAP121 connected to a SF-100-16 ports POE.
The throughput on Wireless is only 34mbps, with a client conencted with N-wireless adaptor
The internet connection is 350mbps
Is it what we can expect from the Wireless throu...
I purchased a new WAP571-A-K9 V01 which is having issues with PoE. When I connect the WAP to our new Aruba 2920-48G-PoE+ switch on port 3/17, I receive the following error when logging into the web console for the WAP:
The power source of WAP device...
I have 2 WAP121-A-K9 WAPs with firmware 1.0.2.3 that I want to upgrade to 1.0.6.2. The first WAP upgraded without a problem. The second will not upgrade, I get the error message: Firmware upgrade has failed. Please ensure that valid entries are sp...
