Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi Cisco Community
We have 2 x WAP121 connected to a SF-100-16 ports POE.
The throughput on Wireless is only 34mbps, with a client conencted with N-wireless adaptor
The internet connection is 350mbps
Is it what we can expect from the Wireless throu...
I purchased a new WAP571-A-K9 V01 which is having issues with PoE. When I connect the WAP to our new Aruba 2920-48G-PoE+ switch on port 3/17, I receive the following error when logging into the web console for the WAP:
The power source of WAP device...
I have 2 WAP121-A-K9 WAPs with firmware 1.0.2.3 that I want to upgrade to 1.0.6.2. The first WAP upgraded without a problem. The second will not upgrade, I get the error message: Firmware upgrade has failed. Please ensure that valid entries are sp...
I want to isolate traffic from my guest ssid in a seperate vlan and just route it to the internet, but clients on that ssid don't receive an ip address:
Here's my setup:
RV180 router :
On all ports vlan id 1 is 'untagged' and vlan id 2 is ...
I have the above access points in our network WAP200 Wireless-G Access Point- We have two VLANs in place, one for guest the other one for the corporate network.
Is it possible to have SSID one(corporate network) be in one VLAN and the other S...
We have a office network setup to support up to 20 staff. I'd like to add wifi access to our office network and looking for a reliable Wireless Access Point that can be plugged directly into the RV320 without additional controllers or hardware i...
We have an office with 50 users (80 devices) and 2 WAP561 Access Points in cluster mode. We're finding the network slow at times and would like to upgrade so devices can connect at higher speeds and access points that can handle higher loads. We're...
Hi Friends,
I have an access point WAP4410N. (Version: 2.0.7.8 ) When this was connected to an unmanaged switch port, it was working perfectly. But when I connect it to a port of Cisco 2960 switch (Flat switch), the AP hangs frequently. Some users ar...
1. Yesterday I've got WAP371 to replace an old Linksys AC router that I used as an AP. Powered it with third party 12V/3A power supply. Connected it to SG200 switch, untagged 1G access port.
I did a MINIMAL configuration - same SSID for both b...
We need to setup an isolated guest network on a yacht.
There are three WAP371 access points wired to an SG200-50P switch. The 3/4G/WIFI router is connected to a non smart SG100-08 switch and this switch is connected to the SG200-50P switch, se...
Hello, my WAP312 just lost the WLAN signal and is not accessable over LAN. It is only flashing its Power LED, nothing else. I already tried a reset (30 sec holding of the reset button). Do you guys know a solution for that, or is this a repair case f...
we have at a remote site 2 x 5508 WLC as primary and seconday not HA.
we both were booted all of the APs associated with the secondary Controller.
I check the config on the AP and it is setup correctly to have the Primary first and the other controll...
Good morning,
I tried to extend the signal from my router RV130w with a WAP AP 321 but with unsatisfactory results (network slowness).My setup is as follows.
RV130w (updated firmware):- BGN Mode, Band 20MHz, Channel 1- SSID without security mode- Rou...
