Resolved! adding . on changing tftp alternate option 8845
Dose anyone know how to add the altrnate parameter of TFTP address on 8845. User access menu but doesn't now how to add (.) when typing ip address.
Hello!How Can I block incoming call for specific calling ID in Call Manager 12.5? I am using MGCP gateway.
Dear, We have an issue of rules in voice translation-rule limit.As we know there can be only 100 rules and for now we have 81 in Inbound and 83 in Outbound.We have to create 2 new voice translation-rule (for Inbound and Outbound) And the question - i...
Dear Community,we have troubles with some Lenovo notebooks with Realtek PCIe GbE Family Controller, using UltraDock 40AJ.Those notebooks were plugged behind a Cisco IP Phone CP-8851 or CP-7811.Always seems to work normal, but when users join a WebEx ...
I have a need to receive calls only on one phone which is a 7941G with an assigned extension. The phone will not have an outside direct number and I only want transferred calls coming in to it. Is there a way I can disable any outbound calling, inclu...
Hey allIn no way am I experienced in Cisco switch/router/IAD provisioningBut i have programmed a few PBX in my timeHaving a tough time getting inward calls from My T1 pri to get to The Analog FXS port on a IAD2432I'm pretty sure its a Dial-peer issue...
I Have a cisco CP-7962G but I am not able to register this phone to a SIP account Please help me. I Have upgraded the firmware to SIP firmware and created a SEP{MAC Address}.cnf.xml file for configuration but my phone is stuck on Registering. Thanks...
Hello,I'm running CUBE on C8000v 17.06.1a and found that it not shows DTMF events with debug voip rtp session named-event 101. The same debug works with older CSR 1000v. Is there a workaround except using monitor capture? Regards,Maxim
hi, need to know if we need to open UDP 16384 – 32767 from IP phones subnets betwwen different clusters since these subnets are different from CUCM or no need jut we will open below ports on CUCM subnets on both cluster office 1permit: TCP 1720; TCP/...
Hello, I have installed CME 12.0 on CISCO 2911 with CUE module, all the SIP phones are registering properly and working fine. The CUE module is also configured and working fine with the voice mailboxes. I have also configured the Auto Attendant w...
Hi all,I've just started with a new employer and they have around 450 phones using CUCM v7 (I know, it's ancient, we're hopefully upgrading soon). My CUCM knowledge is just okay, I've never really had to get into the nitty gritty of the back end set ...
My Cisco Jabber is suddenly giving some users a cannot communicate with the server message. Was there an update that may have caused this?
hello cucm 8.6.2 have got 5 ata-190, and all of them have one problem - it drops registration and became unregistered after some period of time. after reboot it works fine several days and then drops it again. tried different firmware (now it is A...
Hello guys, I have some issues with Fax over IP via SIP trunk. The scenarios is:ITSP-------SIP-trunk--------VoiceGW----SIP-trunk---CUCM--------ATA186------Fax a few days ago fax stop working. Fax ringing after that starts play annoying FAX signal and...
Has ANYONE ever set up a modem passthrough on a VG204XM (or other) for Microtel Series 1000 Dialer? The latter is being used in a SCADA network and we're getting rid of POTS lines. I've attached the latest Microtel manual from 2007 for the curious. T...
Subject | Author | Posted |
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM |
User | Count |
10 | |
5 | |
4 | |
3 | |
2 |
