IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5649 Views
  • 14 replies
Hi all,We have module NME-CUE "end of life software" with version unity 8.0.2.We are going to remplace for new module SM-SRE-710-K9 with CUE version 8.6.7 (CUE 8.6.7 is compatible with our CUCM ver 8.0).I have question about backup compatibility betw...
We have the task for replacing around 2,000 model 7960 series phones with shiny new 8841 models.  Physically swapping the phone is easy enough, but transferring the device description, DNs, and speed dials will be tedious at best.  Especially since t...
Morning All,Hoping someone out there can help resolve an issue for me.In a previous role, I was configuring a CUCM v9 the day before I left.It was a fresh install.I started creating routing patterns and noticed that if I created specific routing patt...
ashleyBT1 by Level 1
  • 253 Views
  • 6 replies
Hi,does anyone know how i can display the Enterprise Alternate number settings on Callmanager CLI? I'm using Version 10.5.I got some troubles with my SQL-statements.. How do i get the CTI route points with the CLI? I need to set the Number Mask on th...
I am using CUCM 10.5.1.10000-7 and am using ILS to propogate dial plans between two clusters.  We use quite a few CTI route points but so I generally import them into the cluster with all the appropriate settings and line association settings. I need...
Hi All         We migrated from Avaya G3r to CUCM 7.X in our new office and currently have two issues related to Modem Passthrough.  If we initiate an Modem > V 224 (MGCP) > outward > 3845 (MGCP) > E1 Controller PRI > PSTN Modem Dail-up this works fi...
I am preparing for CCNA Voice Exam (640-461). I know that it is going to be retired on September 17th 2015. I would try to give the exam before that date. I was studying Intercom in CME from Official Cert Guide by Jeremy Cioara and Michael Valentine....
i show this meesage on CM :  The system is operating with an insufficient number of licenses. If additional licenses to cover the shortage are not configured in your Enterprise License Manager within 20 days, you will no longer be able to provision u...
