Ok, here's a challenge for you :-) I have CUCM 10.5 linked to another phone system (different brand). For the time being, there will be users on both systems and sharing the same number range. My challenge is figuring out a way to (on the CUCM si...
My RTMT sent alerts in the middle of the night marked critical, however trying to understand what the issue was is a bit tough. Can anyone point me to documentation that explains the RTMT alerts or tell me what this message means? At Sat Apr 18 03:0...
We are suffering this bug: CSCua28559So I've needed to remove HSRP and reload the CUBE as it is under production.Bug says remove the bind to the interface under the dial-peer. Does it means we are forced to use the HSRP address?Using another physical...
We have a user that has recently reported that for the past couple of weeks his phone will reboot daily and erase his call log. I have witnessed the phone rebooting and indeed when you look at any of the call logs that would normally be kept, the pho...
Hello, I'm facing an issue here were i can't dial out towards the ITSP from my Cisco UBEI've been assigned a number range to test, and i have been trying to dial out. The call does not go through, it hits the CUBE from the CUCM but then it seems to d...
Greetings! My ip phone 9951 is not creating objects from xml service, it just returns xml code. This could be explained by the fact, that I'm doing something wrong, but I CAN see my service working as intended from another ip phone (model 8945). I h...
Haiwe are going to implement a campus network with 3850 switch stack and 4500x distribution and 6500 core.the ip telephony system is avaya,i need to provide end to end qos support.Anybody help .suggestions,i prefer service policy model .video confer...
Hello, We have a UC560 on CCME and our Carrier has enabled a CPS service where we have to dial 16000 to access free calls onto our company mobile phones. However I would like to configure the system so that the Staff do not need to Dail 916000 in-fro...
Hello, Is there an easy way to get an overview of all the scripts that are being used in UCCX 7.XWe see the need to document alot of them Kind Regards, Yannick Vranckx
Hello, I have a SIP phone (7821) and SCCP phone (7965). I`m using CME 10.5. Is it possible to monitor SIP line (voice register dn) status on SCCP phone? Regards, Kamil
Unsure if this is the correct place or people would know. Our reseller has advised that the Cisco 7942 list price has recently gone up $100. This phone has been out a while now and would not have expected such an increase.Can anybody confirm or deny...
Hii, I have cucm10.5 and I want to buy a videoconferencing solutions for our organizations. What you think about SX20 as solutions.What we want? - to be able to call : in our WAN, to an External customer ( IP) , to ISDN conference From what I kn...
HiI'm going to restrict come DNs to place any call but, I need them to be called. Thanks.A.E.
Dear Friends, Could you pls suggest me a Cisco IP Phone model name which has a fixed stand? I mean not like 7960 or 7962 movable stand, it should be fixed like we had it for 7912 model. This is because I receive too many IP Phones with broken stand f...
Hi,I am facing the FXO disconnet issue in UAE, I have the disconnetc parameters but these parameters are not solving the problem, is there any way to capture the disconnect tone parameters.Regards,
Subject | Author | Posted |
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM |
User | Count |
5 | |
2 | |
1 | |
1 | |
1 |
