IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6176 Views
  • 14 replies
Please help I have a requirement for IDIVERTCaller 1 dials user 1User 1 diverts CFNA to user 2User 2 answers the callCan User 1 then use IDVERT to the call to User 1 voice mail?Now with enhanced how many transfers can you have and still send it back ...
iptuser55 by Level 6
  • 2455 Views
  • 1 replies
CUCM LDAP integration non SSL works fine. When trying to turn on SSL the host name cannot be reached. Did the following:1. Created and uploaded Cert to tomcat-trusts2. Opened Cert and found CN=wwww.xxxx.yyy.com3. Put this as server in LDAP Server set...
eemge by Level 1
  • 1907 Views
  • 5 replies
Dear sir,I will integrate cisco callmanager with avaya pbx through h323 trunk and the end points on the avaya system will do the external calls through the external lines that connected on the cisco callmanager so the question here can callmanager ge...
Hi,I am facing echo issue while making conference on speaker mode. I have done some testing on 3 scenario. Here are the scenario:1. Call from one extension to another was working fine on speaker mode.2. Call between 2 mobile phones and 3 extensions (...
