IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5931 Views
  • 14 replies
Hi,I tried to configure tcl script that will match an incoming VOIP dial-peer. But the script couldn't be loaded. and i get the below error %CALL_CONTROL-6-APP_NOT_FOUND: Application XXXX in dial-peer 12 not found. Handing callid 4415 to the alterna...
We have recently installed a CME system running IOS 12.4.22.T1. CME version is 7.0. We have a T1 CAS using all 24 channels. Is there a way to get caller id to display on inbound calls?
budmiller by Level 1
  • 1113 Views
  • 5 replies
I need to configure the Idle Display for CCM 7. and to configure it I should put XML file in a web server and point the URL Idle field in System > Enterprise Parameters to the web server. Can I use the CCM as WEB server?? If No can use Unity??
