IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6721 Views
  • 14 replies
Hi,I'm trying to create a voice dial-peer where I can dial 7 digits but only have 4 of the digits forwarded to the appropriate GK. example:dial-peer voice 1234 voipsession target ipv4:myGKipAddresscodec g711ulawdestination-pattern:555....In destinati...
fredj1234 by Level 1
  • 461 Views
  • 2 replies
I've been reading around this... is this possible ?I am using a 1760 as my Gateway, I have FXS and FXO, I would like to have voicecalls inbound on the FXO go to CCM and onto IP Phones, and the FAX to go to the fax machine on the local FXS port.1. is ...
I have a FXO port connected directly to an exchange line, when I ring this line and look at the "show vOICE PORT SUMMARY" output I get the following:Operation Status StatusDorm ring-det on-hookup idle on-hookit alternat...
reidg by Level 1
  • 777 Views
  • 2 replies
Is there a way to record calls in CUCM 6.0(1), or is that going to be handled with a third party software or appliance? I know Cistera does that sort of thing, but I wondered if CUCM could do it without a third party anything? I have not seen anyth...
jjoseph01 by Level 3
  • 1093 Views
  • 9 replies
Good evening everyone. Hope someone can help me figure this one out. This past weekend I converted a client from a Nortel Option 81 to a Cisco system running 6.1(2). The local PRI's came up just fine but the long disatance T1 never came up. I get...
Can I upgrade Unity from version 4.05 directly to version 7. I cannot find documentation for this version upgrade. My local PSE says this can be done. TAC has mixed results. One engineer says yes, another said no.....go figure. Has anybody done this?
jsheppard by Level 1
  • 322 Views
  • 2 replies
I have a cm 6.1.2, the problem is that when i receive an international missed call i can not reial the number because the 00 is missing from the number (example: 944161....)The call manager is connected to pstn gateway but there are no translation ru...
Hi everyone, does anybody knows something about this message appearing in the IP Phones "High Traffic Try Again Later", i was doing a little research and i only found this in a Call Manager 3.3 or 4.1 design, im using CUCM 6.1 latest version.Regards
