IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6181 Views
  • 14 replies
I have a system with 4 FXO ports and I have a total of 16 dial-peers configured for these 4 FXO ports. The 16 works out to 4 dial-peers for each FXO since each dial-peer matches different outbound call types such as local, ld and intl. Can I use a ...
tato386 by Level 6
  • 7925 Views
  • 3 replies
Hello,I have a 2801 with the cme ver 4.0.2.I want to connect 7945 and 7937 conference station. I think the ios that supports the 7937 is ver 4.3.I tried to install it but there was a problem in the pstn lines after one minute every telephone call was...
Hi,I configured 2801 router as gateway through mgcp with CCM 4.2(3). Gateway has FXO modules with analog lines. Outgoing calls are fine but when someone from out side dial inside and phone inside start ringing. If caller disconnect call but phone wil...
I think i have a issue in the switchport configuration of the VG248. When 'switchport voice vlan 10' is configured, the VG248 will not communicate to the entire network. Instead, when 'switchport access vlan 10' is configured for the same vlan, it wi...
