IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5822 Views
  • 14 replies
I've been trying to research the "mgcp rtp unreachable timeout command". Although there is plenty of information about this command I have been unable to find out what an "action notify" suffix means. Does anyone know?ThanksJustin
I have been going back and forth with the service provider. We have a PRI handling off net calls which gets roughly 1 slip and 1 sec error every 30 seconds. This is causing echo and dropped calls. Attached is a copy of the PRI config any ideas would ...
248SHaune by Level 1
  • 882 Views
  • 8 replies
Hello,Does anyone know what is (On the Cisco CCM) is a key sequence that the user can dial i.e. 8001 or 8002 to turn lamp on / lamp off in the config?orWhat is the key sequence to add / remove the message waiting lamp on the Cisco phones? User IP Ph...
maddox-mp by Level 1
  • 248 Views
  • 1 replies
Hello,Does anyone knows from where I can download OS Version 2000.4.3.a?I was looking into Cisco.com download voice software links and all I can find is either OS upgrade, either OS Service Releases, but not OS.Many thanks in advance,Maddox
  • 234 Views
  • 1 replies
i m vvv confuse abt this concept....first of all whats the difference between these three and secodnly in which environment we will deploy MGCP or H.323.......in depends on what that we will choose SIP in out network or the other two....thanks a mill...
