IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5398 Views
  • 14 replies
hi.. what is the common implementation to connect pbx with cisco router? is the connection actualy just by plugging short cable? what necessary frame/signaling needed? i mean something like pri,unframed/framed/channnilized? would please give me under...
jemekeren by Level 1
  • 285 Views
  • 1 replies
Resolved! 7941GE with ccme
Hi all,i'm not able to load the network-locale IT and user-local IT on ip phone 7941G-GE.Actually, the ephone has type parameter set to 7941GE, and cnf file are already create (create cnf-file command).All fine with 7940, 7912.... ecc. ecc.Any idea?
d.rocco by Level 1
  • 690 Views
  • 9 replies
Resolved! ISDN handset ring
I have an ISDN handset connected to a VIC2-2BRI-NT/TE card.Have dial tone and can place calls to other Voip on my system.I have created a dial peer with destination pattern 250.If a call a voip phone it flags the call as comming from 250. If I dial 2...
