Hi. I have a Cisco ISR921 router. Can I use it as a voice gateway to establish sip trunk connection with SBC?I don't have voice commands on that and I can't see UCK9 license on that.
The content you are looking for has been archived. View related content below.
I inherited a 2-node Unity Connection cluster and a 2-node CUCM cluster which have the SCCP connections between them. I'm trying to understand how the Unity servers determine how to pass Transfer to Alternate Contact Number calls to the CUCM cluster...
Hello, this is a recurrent question but I see only a very old one. we use Cisco Jabber 14 and 15 and Expressway MRA X15.2.4 is it still needed configure the directory like UDS and build a webserver for load the contact photos? regards,
Hi I am working on a scenario, where I have requirement to configure Hotline Phones in a Point to Multipoint Configuration. One Hotline Phone in a central location and three remote hotline phones in three different locations having different extensi...
Hi , We have a Cisco VG204 , integrated with CUCM v14 on SCCP protocol.The problem that we have one anolog phone makes several calls alone during the day.We don't have any config PLAR .voice-port 0/0mwicptone FRtimeouts initial 60timeouts interdig...
Hi dear Friends,i have an issue with "expressway core"which is when i want to add "CUP IM and Presence" into "Expressway Core"it shows me this error:Failed: Unable to communicate with imp-pub.example.com. AXL query HTTP error "HTTP Error:500"CUCM ver...
Hi Everyone, I have an issue with CUACA Client 14.0.2, with have to migrate the operators to another server and our customer wants to get all the "Personal Directory Groups" and "Speed Dials" manually created. the question is, are there SQL Queries ...
None of my IP phones show up that are plugge into Meraki switches MS250. Is there something needed other than SNMP? do i have to call Meraki?
We have CUCM 15. If I go to the CUCM site using a DNS name, I am brought to the selector page (Manager or Self Care) with the DNS name in the address bar. Selecting Cisco Unified Communications manager I am then brought to the management Login page...
I need some help determining the process and impact of changing my Call Manager names under System > Server.For reference my cluster is version 14. All nodes within the cluster were installed with a host name and the domain name is configured. Addi...
Dears, For your kind support as I am facing an issue in cisco wireless IP phone 8821. The issue is that the cisco wireless phone always gives network busy when making a new outgoing calls as well as receiving calls it goes to a busy network immediate...
i'm trying to insert a new token on my new call manager bit it's causing a timeout and the http and https streams are open to the satellite so i don't know where is the problem
Hello everyone, has anyone successfully deployed WebRTC integration with SBC/CUBE. If so, could you please share a sample configuration and any relevant Cisco documentation links? Thank you.
I been trying to install RTMT in this new laptop and no matter what workaround I use the result is always the same: Error: Could not create the java virtual machine.Error: Afatal exception has occurred. Program will exit. The LT is running Windows 10...
Is there a way to easily map relationships between call handlers aside from iterating through each one manually? I am trying to clean up orphaned handlers and am trying to see if there is a way to tell if a handler is assigned to a caller input optio...
Subject | Author | Posted |
09-05-2025 07:40 AM | ||
07-16-2025 11:43 PM | ||
07-07-2025 05:45 AM | ||
06-26-2025 03:23 AM | ||
06-18-2025 01:32 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
