Hi team,Just wondering if anyone can provide me with the PoE budget of the built in 8 port switch on both the UC520 and UC540 models?This information doesn't seem to be listed in the data sheets.Thanks,Alex
Hi. I've just implemented a new UC560 install for the company I work for. Over all its gone well but we seem to have an issue with redailing numbers from the "Call History" menu.Basically the calls are saved in the list without the "9" prefix, so whe...
can someone point me in the right direction here....Im using a SPA525g ( with SPA500s ) registered to Freeswitch.Im trying to use BLF on the sidecart with this configuration<Server_Type group="Att_Console/General">Broadsoft</Server_Type><Unit_1_Key_1...
Anyone else had this problem? At one point, extensions got shared. That as a mistake as the phones were dual-line. Went back to normal. Now when changes are made to "Voice", the lines get set back to shared. If they are set back to normal, hunt ...
Using CCA tool 2.2.5 withCisco Unity Express Admin version of 8.0.2.Customer needs the following scenario deployed. UserA message notification is set for "pager numeric".UserA is paged and calls in to get voice mail. This scenario works fine.Custo...
I have a Cisco SPA500S connected to a SPA525G the line buttons light up green but do not change when extention is in use. Is there a blocked port or some other issue?
Hello,I've an analog device (Siemens Gigaset Sxx) on an FXS port of an UC500. Our customer wants to see who is calling him. The Siemens Gigaset device supports to present the caller id. Maybe an dtmf or fsk problem, or support the uc500 no incomming ...
Have downloaded the new firmware package, upg-spa2102-5-2-10.exe and spa2102-5-2-10.bin, from Cisco website, but couldn't upgrade my SPA2102 adapter.With running Solarwinds TFTP server in the background, I have been waiting for hours watching the upg...
We have installed many UC540/560 units. This is the first time we saw a unit keep rebooting what make inbound or outbound phone calls. We used different version of IOS, it's always the same result.Anyone ever had this kind of problem or is this just ...
We have a new UC560 and upon initial configuration, it started rebooting almost everytime a call comes through either an FXO or an FXS port. Internal calls work fine and CUE is working fine. I have upgraded the IOS to version 15.0(1)XA3a (that come...
All,We are testing the new platform of UC500 Series – UC560-BRI-K9. The device running this version of IOS: Version 15.0(1)XA and Call Manager Express 8.0.Everything looks fine, but there is a problem with the B-ACD functionality. We configured this ...
I have a newly deployed UC520 that I've setup from out of the box, obviously my first deployment. I've got everything working except for voicemails.I have the mailbox set as 101. I've created everybody's voice mailbox. When the users hit the messag...
Hi,A client of ours is looking for a fully fledged call recording solution (i.e. for a small call centre scenario) whereby calls are recorded automatically etc. (i.e. so something better than LiveRecord). Would you know of any Cisco and/or third part...
Our current configuation of using a UC520 behind an RVS4000 router is giving issues.The WAN port of the UC520 is plugged into one of the ports on the 4000.We have a data LAN that is plugged into another port to a switch.We are only using the 520 for ...
