If you have a DID feature from an ISP, can you only use a DID based voice interface card?Thanks in advance again :)
just replaced Magix with call manager express. connected C1000 controller to unused FXO trunk. mapped the trunk as overlay with other incoming lines on phones. when door box button is pressed, call comes in and i can talk to a person. pressing ** (it...
Hello, I want to know the current logs of CUCM as such of switches and routers we have show logging command which shows us the current logs of any errors,notifications,etc etc Also i want from those logs it should show me that so and so service has ...
Hi all, is there any command for CME router to prioritize preference over best match destination-pettern?I have router connected with CUCM where are several hunt lists but in case of WAN issue I want to have same hunt lists configured on router which...
Hi All,I am trying to upload the file .csv to CUCM for configuring phones in a bulk but ending with a error as "INSERT for 1 PHONES could not be processed'.Could some one guide me how will be the csv file format for inserting phones in CUCM without u...
We have integrated our CUCM 8.0 with Third-Party callcenter solution over SIP trunk. We are facing intermittent one way audio for the calls made from Third-party client, which is installed on the agent PC, to the PSTN.Third-partyClient on PC > SIP Tr...
so some of our users have brought it to my attention that when they dial the voicemail shortcut *4443 it will work and transfer with no issue but if they do *58326 it says "I did not recognize that as a valid entry" then forwards out to the automated...
Hi I am using the vcs-interop script.. but when the calls goes it try to reach a phone xxx@ipcallmanage and I need to change that to xxxx@domain.com I have seend some script but only change calling but not called party... and I also need to know ...
Hello,Is there a feature that would allow a user to callback the caller from the voice message itself. For example Calling number 123-123-1234 calls extension 2000 and leaves a voice message. When user with ext 2000 listens to the message from 123-1...
I have a CUBE voice gateway setup with address hiding. The gateway has an interface going to the carrier and I have a loopback with an internal IP address. The problem I have is when a call coming in to gateway and then it is call forward no answer...
We have a small office (10 users), and we want to get video phones for the entire office. We're trying to decide between 8945 and 9951 (+video camera). After reviewing the data sheets, it appears both will meet our needs from a feature perspective....
When I unpack the phone from the box. I plug the phone for register to cisco call manager. but the phone display picture snoopy. after display I can't press anything with it
Hi all...Is there a way to setup call forwarding to a users external number (cell phone) without programming an IP phone?Here's the story, the regional managers in our office all work remotely and have office of desk here in the corp office, I've bee...
Running Communications Manager 8.5(1) with mostly 3945 router running 15.1(4)M6 at remote sites. Having an issue with dropped calls. The Caller Termination Cause is showing as "Temporary Failure". All sites are dropping calls from time to time wi...
HiMy Cisco 7960 IP phones are registered with SCCP right now. I uploaded sip firmware files in router Flash using tftp server. cisco 2911 ISR router is used as tftp server. After uploading sip firmware I reset ip phones but Phones are still registeri...
Subject | Author | Posted |
06-04-2025 11:19 AM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
4 | |
3 | |
2 | |
1 |
