IP Telephony and Phones
Labels
Hi,I just want to know that below rule would remove 9 from incoming number. Now i am using CUCM 7 with h323 gateway. Telco is sending last 4 digits and poiting to CTI route point. Now at above scenario, whats the use? and where shall i call that prof...
techguy by Level 4
  • 2617 Views
  • 8 replies
Hi All,We are running with CUCM 9.1.2 & LDAP integration is enabled. When we tried to do the Manual sync for one of the LDAP directory & it immediately disappear from the Directory list  in CUCM GUI & all the user went to Inactive state.While we veri...
Hey guys,I have a quick question regarding 911.  We have two PRI's at our home office and a couple of POTS on FXO.  For some reason we were setup for 911 to go out POTS instead of the PRI.  The only problem with this is, if 911 is dialed and then dis...
Hi, I'm looking for the option to send a call to a cell phone (Mobility), on an EX90 and DX650.  On the DX650, I am able to add Mobility to the Phone Button Template; however, it never shows up on the phone.  On the EX90, I do not see a way to do thi...
Good day all - I have an interesting issue. The issue lies in a load balancer (balancing two links). Now the link balancer is not inspecting SIP traffic and is truly just doing Layer 2 acl's if you will. This is the issue, from our Telcom Provider - ...
