IP Telephony and Phones
Personalize banner_3
Labels
Resolved! 8945 DnD alert
Running firmware SIP8941_8945.9-3-1-18When the DND softkey is pressed, a popup appears notifiing you that it is either enabled or disabled. Then it dissapears. There is nothing else to signal that DND is enabled, unlike on the 79XX where there is tex...
networknoob by Community Member
  • 2888 Views
  • 4 replies
I have two connection ,one PRI and an Analog connection(fxo).I want all users to use PRI DID number except receptionist.I want Receptionist to take analog line for both incoming and outgoing call.In coming is coming to recetionist extension 0.But wh...
Hi there,I would like to request for assistance. We are experiencing CISCO IP Communicator issues (CISCO IP Communicator version 7.0) wherein it cannot be installed in a laptop that is using Windows Vista and an error message appears that says that t...
April Molina by Community Member
  • 1072 Views
  • 1 replies
Hi,We have an environment where we have Ascom IP DECT phones attached to a CUCM 8.6.2 platform. The Ascom IP DECT phones register as SIP clients. The Ascom phones register with DECT on an Ascom station (call it a PBX if you want), which then register...
