IP Telephony and Phones
Labels
I know that the period (.), represents any digit. Recently i came over a config wherethe dial-peer looked like this:dial-peer voice 100 voip huntstop preference 1 destination-pattern .. session protocol sipv2...The destination-pattern is defined by t...
ov by Level 1
  • 738 Views
  • 2 replies
Hi,We have CUCM 8.0, IP phone 7975, FXO cardI have 2 FXO ports through which user is doing PSTN calling.We want to monitor the FXO card. If one FXO port is busy, it should indicate on phone line so that user can monitor and can directly use second li...
Hello,Today we discovered that a number of calls are being made from our site to global destinations.  We checked the call manager and the logs are not showing any abuse internally so now our attention is on the router ISDN.  We haven't any access li...
We had a strange issue that I'm hoping someone might know the cause for it. We did a tech refresh for a customer from 4X to 7X for CM(7.1.3), Unity Connection, ER ,and UCCX. All IBM servers (mix of 7835 and 7845 class) with RSA turned on. Servers wer...
SAN J by Level 2
  • 1153 Views
  • 2 replies
Resolved! B-ACD not working
Hi,I´ve a config of B-ACD that is not working on a Cisco 1861. But the same cnfig works fine on others Cisco 1861. Here it is:application  service autoatt app-b-acd-aa-2.1.2.2.tcl  paramspace english index 1  param menu-timeout 6  param second-greeti...
Resolved! 7937 one-way audio
Hi,I am facing the following issue. We have recently installed a 7937 conference station on a Call Manager 4.1(3). To add support for this phone model we added this device pack: ciscocm.4-1-DevPack-72.exe.At this point we can have the phone registere...
sergiope by Level 1
  • 2166 Views
  • 3 replies
I have a new VG 224 but when i checked it on its show running configuration i dont see any voice-port x/x. I tried to configure a voice port configuration but the gateway rejected the command. I also tried to reboot the gateway but the result is stil...
