IP Telephony and Phones
Labels
I'm troublshooting a RightFax issue and am trying to determine the cause of a failed transmission. The context is;- RightFax is attempting to send an outbound fax via H323 trunk to the gateway.- Outbound fails with the following q931 information;Dec...
Hey Guys,I have a question, I have a client with one 7845 (CUCM 7.1(3)) and a single 3825. They want the analog device to failover to the 3825 should the Call Manager fail. My question is can I still setup the VG224's in CUCM using MGCP and create an...
wrickk_2 by Level 1
  • 1035 Views
  • 3 replies
I'm deploying a remote site with four FXO voice ports in a VG on one side of a large room.  On the other side of the room are four lines from the PSTN that are terminated on a 66 block.  I need to connect those four lines into the four FXO ports on t...
jmunoz19 by Level 4
  • 1839 Views
  • 4 replies
I have two 3925 ISR routers with 4 pri's in each one.I am hooked up to a Callmanager 7.1.5 under normal conditions  running MGCP whatI am curious about is when I go into SRST mode, I want to use one gateway for the phones but what is the best way to ...
miket by Level 5
  • 766 Views
  • 3 replies
I have a odd issue, one of our offices when they call a local number they dial 9 XXX XXXX and get to that number, this is as it should be. However when they place that call on hold, select new call and dial another local number 9 XXX XXXX it does not...
nixon1234 by Level 1
  • 633 Views
  • 3 replies
Whe users log on to GUI to update speed call popup error (Voice Profile Not Definded) comes up. Dose this mean voice profiles need to be configured  via CLI so users can access the profile via the web interface?
