IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5866 Views
  • 14 replies
I am aware of a product that can be deployed as a Fax Server appliance from Cisco which is based on Right Fax. I would like to know if the VOIP gateway supports Fax. Can it perform Fax Server Role where it will handle incoming and outgoing fax reques...
Guys,first time configuring PRI for voice and am having a little issue with the telco. they are asking me to turn up my D channel but have no idea of how this should be done.My basic config is as follows controller T1 0/0/0 framing esf linecode b8zs ...
a.gooding by Level 5
  • 12724 Views
  • 25 replies
Hi,In CUCME you can create an XML file and use it for Local Speed Dial. How do I acheive this in CUCM 7.1? I have a customer that wants local Speed dials common to all users in a department. Can I use the same XML files I have for CUCME, How do I get...
p.holley by Level 1
  • 1456 Views
  • 7 replies
