hello alli connect d-link analog gateway dvg-5008s to callmanagereach port of gateway as third-party sip devicebut, i can register just one port, any one port, not allwhere is trouble?
We cannot utilize all the buttons on the Sidecars (7915 & 7916) to their maximum capacity due to the 42 buttons limitation on Callmanager.We are using 7962.IS this something that can be fixed by installing a device pack/patch?If not, does anyone know...
Hello All!!!In the Cisco Unity; I have created a Call Handler for Environmental and Safety Complaints; everything is working fine; but when some user leave a message and I want to check this message; I can´t because I dont know the password; I don´t ...
We have Cisco 2960s connected to a 6905 core. We just deployed VoIP phones to our end users. On each user switchport we issued the command auto qos voip cisco-phone, which I think added these commands to the interface: srr-queue bandwidth share 10 ...
hi all,I have installed CUCM version 7.1.3 (2 servers : Publisher and Subscriber).I have implemented EM redundancy using DNS,i've created hostname in my DNS poiting to both nodes ( PUB & SUB) IP adresses and i've changed the URL service from IP adres...
Guys,Got an issue that I think i s more or less a UCCX requirement but wanted to know if I could do it on Callmanager and Unity.I sort of have it working but as its for a Main reception they way I have done it doenst support enough lines.Scenario.1. ...
We have CUCM 7 and a cluster of three Call Manager serversSubSubDRPubMy understanding is thatWhen a Cisco phone boots, it gets an IP Address via DHCP and is told which server to register to, once it gets a configuration file.According to the group sh...
Hi All,I'm looking for advice/opinions on a UC solution I am proposing for an upgrade/refresh of an existing environment.Currently:CUCM 4.2.3 cluster x3 nodesCCX 4.05 HA clusterEmergency Responder 1.3 single serverUnity 4.2.1 single server Unified Me...
Hi everybody,How can i configure the dual line for one extension in call manager 4.1, i need to be able to receive two call in the same extension.Best regards
Hi,I´ve a CCM cluster 5.1 integrated with Genesys T-Server and GVP working ok, but there is an issue in this case:1.- The call arrives from GW directly to route point (0010) controlled by T-Server2.- When the agent receives the call, and make a trans...
Hi,I have a Cisco 7941 phone and I am trying to get a proceedure to tftp a SIP image and working configuration file to the phone. Has anyone come across this before and got it working?Thanks,Derek
Hello,I am having trouble with dialling the cue voicemail number. I keep getting a re-order tone.I am running nm-cue in a cisco 2651xm and the cme on the cisco 2801 is running 15.1(1)T / CME 8.0The errors I get is:" Last Disconnect Cause is "41 ", L...
hellomy costumer have a problem to set up conference between 3 people and more and move out himselfbecuse he disconnect the conference .under service parameter in the ccm i configure " never" disconnect the callthe way that he move out himself fr...
Hi all,IP telephony and Fax over IP works on our router.We can make voice calls without problem, receive faxes without problem but when we try to send fax, it does not enter the correct dial peers and cannot be sent.When we open the isdn q931 debugs,...
Hi Guys,Is there a way to make CallForward from CUCM send the forwarding stations number as the calling number when forwarding calls to a SIP trunk?Currently, when making external calls, users dial "0" then the number. THis is working fine sending ca...
| Subject | Author | Posted |
| 10-17-2025 09:01 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 6 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
