Hi All,My customer here needs when leaves meetme conference all other participants who had joined the conf. to be dropped,the same like AD HOC conference.I have CUCM 6.1.2Any Ideas,Ahmed Kamal
Hi,Dial by name option in AA is a little inconvenient when there are users with the same first name or same last name, the systemspell the names and the costumer prefer to listen the complete names.is it posible to do that by means of a new scrip...
Has anyone ever implemented Emergency Responder with a Globalized Dial Plan? What what I've been told CER has not been tested with a Globalized Dial Plan nor does it claim support for it but I'd like to know if anyone has attempted this?Any feedback...
hi all,i am facing one issue on analog lines connected to cisco 2851 routerthe issue is, when an incoming call comes to reception it is ringing but when she tries to pickup the call is disconnecting automatically.i dont know from where problem is , a...
Good morning guys,I am building a lab environment for CUCM 8.x with the NFR 8.x suite of S/W. At the time the IBM I3 was the only server Cisco supported for 8.0(1).I ordered a server direct from IBM 7947 model 22g and have 4 gig ram correct processo...
Hi,we use many VG204 and VG224 with SCCP to connect analog phones to call managers.Without security everything works fine.Now we want to switch to authenticated mode with the command "stcapp security mode authenticated" or "encrypted" only.We had man...
Hi,I believe its very easy to integrate CUCM with Exchange to handle all voicemail. Since we can no longer buy any Unity 4.2 licences im going to totally move it over and have exchange handle it.Ive tried to find a guide to do this on the WWW but can...
We are planning to install a pair of Unity Connection Servers 8.x which will config as a HA cluster.This pair will be sitting in two different cities and these two cities are in two different timezones.Will the Unity Connection Server HA cluster supp...
Hi all,I'm using CUCM 7.1.3 and 2811 with FXO port as MGCP gateway. Each user is using softphone. When there is incoming call to softphone, the user complain that the sound is small. I've tried to increase the volume of softphone to maximum and incre...
We have Unity version 4.0(5.0) running on a Windows 2000 server. I'm looking to confirm if the ServerUpatesWizard-v3.0.07-07-2010 will have a patch in it for "Microsoft Security Bulletin MS10-046 - Critical" < http://www.microsoft.com/technet/securi...
Is there a way to increase the volume of a call on 7900 series phones from the UC? I have a customer that is complaining the the volume level is not loud enough after adjusting the volume to the max on their phones.Thanks,Mario
I currently have a CME install with a CUE module. We are using the AA for basic call routing. We have one issue. When we dial the main number it always goes the AA. There is a generic greeting and you can dial an extension at anytime to reach you...
I recently setup a CUCM 7.x PBX for a hotel in my location. The Customer wanted all calls from Hotel Room to Hotel Room and from Hotel Room to Courtesy phones to block the caller id from the displays.I followed the "Display Restrictions" section Of ...
How can I user/device specific settings using BAT tools? such as speed dial settings, shared line etc etc. We are migrating 250 phones from cm 4 to cm 7. Its a fresh install and we did not use DMA.We are also upgrading Unity to version 7 and would li...
hello alli connect d-link analog gateway dvg-5008s to callmanagereach port of gateway as third-party sip devicebut, i can register just one port, any one port, not allwhere is trouble?
| Subject | Author | Posted |
| 10-17-2025 09:01 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 6 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
