IP Telephony and Phones
Labels
I can't seem to do it across the VPN. Everyone is default g.711Internal it works fine.The site across the vpn can not do conferencing. So it seems that something is off. I just can't put my finger on it.I have the CFB confgiure and have the MRG in bo...
Hi all,We're deploying IP Communicator alongside a 3rd party SSL VPN which advises it supports Cisco IP Communicator 1.x+ using IP pool allocations. However, I've not managed to get it to work unless I specify the IP address for network audio manuall...
Hi,can soneone please help, I have our remote sites registered to the the Call Manager Cluster with SRST in place if failure on the main WAN path. However a couple of times now on a main WAN failure the telephones have correctly registered to the SRS...
The problem is I dial my voicemail pilot number, the call is picked up but I don't get any audio output from Unity. I would expect the usual 'Please enter your PIN' etc…I am running:Cisco Unified CM Administration (7.0.2.20000-5)Cisco Unity Express...
mmoulson1 by Level 4
  • 634 Views
  • 1 replies
