IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5805 Views
  • 14 replies
Resolved! upgrade Unity
Guys, sorry about this, but Im unclear on this as well. Im looking at upgrading Unity 4.0. I want to know what the furtherest version of Unity I can go with Win 2000 is and what version wont work with Win 2000?
jjoseph01 by Level 3
  • 574 Views
  • 14 replies
Can anyone tell me how I can control the number of calls going across a wan link. I am aware you can use locations in CCM. This scenario however is different. 1 site is ccm and the other is a PBX. They are connected via 2 routers using QSIG. I was ho...
pcromwell by Level 3
  • 258 Views
  • 1 replies
Hi,I am having trouble getting Conference Calls to work. I call a phone and after the call is active, press the Confrn button, dial the second line and call is active but as soon as I press Confrn again to bring them all together the two phones call...
skroesen1 by Level 1
  • 1286 Views
  • 4 replies
Hi All, is this possible to dial to CUE AA from outside and then dial password in order to make a call through CME system? In this case, outside user can dial to AA company and company is getting charge instead of user. any suggestion would be very a...
I'm setting up CUCME on a 2851 running IOS 12.4(9)T7. I set up the phone loads and uploaded the firmware files, but the two phone types I have, 7941G and 7911G aren't liking it. The 7911's loop through a Cisco and "upgrading" screen, though it does...
gmgarrian by Level 4
  • 760 Views
  • 1 replies
Having issues using Grant unity access tool to tie an AD user to a subsciber, have performed this successfully in an exchange environment. I consistently get the error subsciber id not found, as if Unity cannot see the Notes based subsciber. The Unit...
I am having issues getting a fax machine connected to an FXS port configured with H323 to successfully fax directly to another Fax machine connected to a VG224 using MGCP. If you dial externally, it connects correctly and faxes correctly. If dialing ...
What's the best way to do this upgrade? To first upgrade to CCM 4.13, and then use DMA and go to 6.12? Or, upgrade to 6.11, using DMA, and then upgrade that version to 6.12?Currently, 2 server cluster, 4.02, MCS-7815 servers, going to new servers.T...
mwheinz by Level 1
  • 202 Views
  • 1 replies
