IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6134 Views
  • 14 replies
Quick question: If a PRI has been ordered and provisioned to use ISDN protocol "NI-1" what does this correspond to when configuring the "isdn switch-type ????" command on the PRI?Do I use "isdn switch-type primary-ni"?TIA for any assistance
flash2200 by Level 1
  • 832 Views
  • 2 replies
I'm having problems with my telco reclaiming ports because they are not being used. I have a device that can place a number of calls to my 5350s, but the calls require the terminating end to press 1 to keep the call up. I'd like to take the attached ...
rjrii by Level 1
  • 214 Views
  • 1 replies
Hello, Let's say first and foremost, I'm not a voice guy. I'm trying to get a voip lab setup and I'm having strange issues. I have CCM 4.1(3)sr4d with an IP Communicator soft phone and a 7961 IP phone. The out side connection is a SIP trunk provi...
