IP Telephony and Phones
Labels
I was reading the CM 6.1.2 Release notes and there is a step below-Step 3 Use an md5sum utility to verify that the MD5 sum of the final file is correct.Does anyone have a suggestion on a particular utility that they have used.
shane.orr by Level 4
  • 3413 Views
  • 2 replies
Hi Guys,Have a situation when calling in from the pstn the calling party does not hear the destination phone ringing but only them pick up.Added the voice call send-alert which sorted that out but it is still happening on internal calls between exten...
Dear Seniors.This is regd call park. when i retrive a call after parking, it is getting delayed for 4 - 6 seconds for retriving it.After dialing the call park number, it takes 4-6 seconds to retrieve the call. What could be reason. where to check, wh...
esa786_2 by Level 1
  • 466 Views
  • 2 replies
Hi Probably a really stupid question but....I have CME everything is working fine however all incoming calls are showing up as unknown number. I have searched on google but all I could find was to use the caller-id enable command on the voice ports h...
Dear allI have PBX system and a router with 16 FXS port. the PBX connects to router via E1 CAS and fxo-loop-start signal.The PBX guy told me that he has defined 16 extension on E1 link.So I want to hear PBX dail tone on my FXS phones.the sesond issue...
miskoolak by Level 1
  • 303 Views
  • 1 replies
