IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6164 Views
  • 14 replies
CUE
hi,I am running CUE with CCME. When I configure the time on the CUE, i select timezone Europe and Ireland. When i save and reset the config the time comes up 2 hours incorrect. The time on the CCME is working fine. The version of CUE is 2.3.4. Has an...
Today's problem is I'm unable to see/enter CUE GUI. CME is up and functioning and I've gone through the CUE initialization wizard. When I attempt to log in to http://10.0.200.1/ccme.html, I receive a login pop-up, put in the usrn/pswd, and receive ...
Hello,I need to raise our Domain functional level to 2003, but my boss is concerned how this may affect our phone sytem. We are running Call Manager 4.1 on a Windows 2K Server box, but it is not a domain controller. Our phones are also on their own ...
bergquist by Level 1
  • 411 Views
  • 2 replies
Hi All,Could it be possible to use my 7204VXR router for routing calls from Avaya Definity phone system between our intranet connections on an E1 pipe?I will be going to connect my 7204VXR router to the DS1 board of my Avaya Definity,our intranet end...
capajaron by Level 1
  • 580 Views
  • 5 replies
