IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6559 Views
  • 14 replies
Whe I try to upgrade the Subscriber to version 5.1.2.3000 the Call Manager is not able to find the parch from the DVD disc, in the Install Upgrade Retrieval Mechanism I select Local, and I insert the DVD with the patch. I recorded the patch with the ...
Hi,I configured IOS Enhanced conference bridge for CCM 6.0. when I create an ad-hoc conference the ip phone that creates the conference can not be heard yet can not hear other participants . Other participants can hear each other without any issues. ...
Hi,The users I created can not access ccmuser webpages, I get "Invalid User ID or Password" error. I added end users to Standard CCM End users user group which gives CCMuser access to endusers. I also associated the device with the end user, selected...
Hi there ,i would just like to know whether it is advisable to change the cluster ID`s from the default in an already existing Callmanager environment ,if possible what the steps are and what the possible risks are. The environment only has 2 callman...
bcxuser01 by Level 1
  • 540 Views
  • 0 replies
I have been investigating issues where certain phones traffic is not passing QoS parameters across the LAN. I started walking back through the network and got all the way to the access switch where I did a "show mls qos inter fa XX" and found the fo...
djohnson by Level 1
  • 4857 Views
  • 10 replies
