IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5903 Views
  • 14 replies
We're using CCM 4.1(3)sr5b, IPCC Express Premium 4.0(5)_Build042 & CAD/CSD 6.1(5). CAD is installed on two MS Terminal Servers serving 70 (will be closer to 200) Neoware E90 thin clients running Windows CE. All is fine except agents disappear and ...
I am receiving a massive amount of errors in my tsp log files:CiscoTSP001.tsp|<--CSelsiusTSPCallList::IsValidCallHandle() |<LVL::Entry_exit><MASK::0001>Can anyone tell me what this error means?
jgale by Level 1
  • 250 Views
  • 1 replies
Resolved! FXO and FXS ports
I need to know how can I get 24 FXO ports in a ISR router and what model.Also I need another ISR router with 8 FXO and 10 FXS ports which model and configuration (EVM,NM,etc) is the most effective?. Be aware that i need at least other 2 free slots fo...
We are having some problems with IP Phones resetting themselves. IP Configuring pops up or CM Down. Nothings changed on the config recently.Could be a separate problem but one of the nics on the server stops responding randomly, I have to disable a...
pody_work by Level 1
  • 265 Views
  • 1 replies
