HiPlease can you tell me what is going to be in the 2.2 release and when it is to be released, a client of mine has requested softphone users and i was wondering if this feature is going to be added.Thanksdave
Good Morning Everybody,Quick question hoping someone can answer.I have a customer with a UC540 who has both SIP trunks and FXO trunks to the PSTN.All the employees use 9 as an access code to make an outbound call, and the outbound dial plan selects S...
I have a UC540 with SPA525G phones. Under telephony server on the UC540 I've put directory entries:directory entry 1 1234567890 name "User"etc.etc.Now this list shows up in the directory on the phones but I'm not getting the option for abbreviated d...
Hello all,My two Conference Stations can't download this files: its/SEPC0004F2EDD479.cnf.xmlits/SEPC 0004F2EDE173.cnf.xmlThe File exists on the server. The other phones (SPA525G2 and 7921) download their files correkt and work fine.Did somebody have ...
Hello All,Does anyone know of anyway to keep the 'Call Focus' on the current call when then next call arrives.I've looked through all the settings and cannot find an 'Auto Call Services' option. (SPA508G)Any help would be greatly appreciated.Regards,...
Hi, I'm installing an UC320W and I'm having a bit of a trouble setting everything up. I have almost everything up&running, but I can't find any way of configuring any kind of outgoing call routing. I'm using four analog lines for incoming/outgoing ca...
Hello!I'm trying to create LDAP (Microsoft AD, Win 2008 based) address book, but phone displays empty fields in LDAP return data, when russian letters present in that fields.There is no problem with english names and digits.AD are Win 2008 based.Does...
Hi all,The short version: how to reset/disable admin password in SPA-941 phone?The long version:I have an IP Phone SPA-941 --- bought it on eBay with 'lost admin password'. I've found somewhere on the Internet that it's possible to reset the phone t...
Hi to all,Previously: I had a SPA9000 with some other devices and IP Phones (more info is not not relevant). The thing is that when browsing to the SPA's IP address I could see which phones were making or receiving a call, the number they were dialin...
Hello,I configure an SPA2102 for a fax (HP 2840 Multifonction Printer).I upgrade SPA2102 to 5.2.10 firmwareWhen I send Fax, all is okBut when I want receive a fax, the fax machine doesn't answer (no ring). I connect an analog phone after the Fax for ...
Hi!I'm having problems where the device fails registration using UDP but works with TCP. The response from the server is FORBIDDEN when I use UDP. I am only changing the transport, so I know the password is correct.The difference I see is that the A...
I'm setting up a Cisco SPA502G phone and get the phone's display panel to work, but I can't get a dial tone.The set up involved hooking an ethernet cable from my Cisco E3200 router to the phone's SW port, and then connecting another ethernet cable fr...
I am hoping that someone out there can help me. I am trying to setup the other extensions (1-4) on the SPA504g phones in my office and I need the subscriber password for each extension. The problem is I did not setup these phones and the guy who di...
using PAP2T. I forgot the password.I can not enter the ip address of the interface at the moment. but it also does not try the following way. not start again.IVR 73738#Passwords I tried:* 78196365* 50274537* 7756112* 8995523* 5465866in the above figu...
