IP Telephony and Phones
Labels
I'm having an issue where DTMF isn't always being transmitted in realtime.  It seems like there can be a pause and then a bunch of tones sent all at once - very fast.  We have not made any changes to server or gateway settings recently.  I'm running ...
I was testing SRST and was trying to configure an outbound dial-peer.  The problem I am having is the total number of digits to pass to the PSTN.  It varies by country.  has anyone had any luck with this?I tried the solution in this thread - https://...
cplatt01 by Level 1
  • 1360 Views
  • 3 replies
hi im having some problems when i try to do calls from an out source to the local numbers in my red, this not sounds,  its like we not do any call.i check another configuration of this red and i note that this commands are left.voice call carrier cap...
jsotooplk by Level 1
  • 959 Views
  • 4 replies
HiI want to make an script where i can set a boolean expression to true if a particular supervisor is logged in in a particular CSQ,Kindly let me know how can i trace supervisor login  and also get the name of the supervisor who are logged in , also ...
I have an ATA 186 that isn't sending DTMF correctly (I think). I can make calls, but when it comes to dialing a number while connected to an automated system or whatnot, the receiving end doesn't receive or recognize the number I press (press 1 for s...
