IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5569 Views
  • 14 replies
Resolved! VoIP Solution
I have to implement a VoIP solution for a new facility which will house 150 users. If I use Cisco's solution, what do I need to get. Basically, I am trying to come up with a shopping list to implement Cisco's VoIP solution.Thanks,Mohamad
hi! Is it possible to enable password for outgoing international number on a paticular ip phone only and the user is still able to call local number without passcode? If yes how can that be done?recently, we've issue our call attendant number (the co...
dave dave by Level 1
  • 336 Views
  • 4 replies
Guys, in the compatability matrix for CUCM v8 it shows the minimum supported IOS for the 2800 voice gateway is 15.1... Is this correct, so v 12.4 will not work with CUCM v8?Is the 15.1 upgrade free to download or are new licenses required?Many thanks
rays by Level 1
  • 454 Views
  • 2 replies
Guys, i am upgrading from version 4.1.3 to version 8.. My plan was to upgrade to version 7.1.3, import customers DB and then upgrade to 8. The problem is the new hardware has arrived with version 8 pre installed. What is the best option to me now?Can...
rays by Level 1
  • 312 Views
  • 3 replies
