IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5457 Views
  • 14 replies
I have recently change from CCME 4.1 up to8.0 and was having an issue with a 7941 phone load.  Thought was to factory reset the unit so that it pulls the latest load form the CCME term41.default.loads.The factory reset procedure works fine but when i...
abrashic by Level 1
  • 3067 Views
  • 4 replies
Guys,running into a wierd issue where my CPU utilization is going over 90%. processes showed CCH323_CT as the process taking 48%. sent the show command to output interpreter but it advised that it could see a high utlization but no process was causin...
a.gooding by Level 5
  • 1539 Views
  • 2 replies
We are running CallManager 7.1(5) and the Administration page will not load. I tried to restart the Tomcat service but had not luck. I went to the console and it is scrolling the following message:ext3-fs error (device sda6) in start_transaction: Jou...
Hi,We need to generate a missed calls report from CCM 4.2CDR flags are enabled and "Log Calls with Zero Duration" flag is also enabled.The problem is that all missed calls are logged in the CDR with a Date of "0". The "dateTimeConnect" is always Zero...
sharpgate by Level 5
  • 928 Views
  • 3 replies
the Plantronics corded  H171 & H171N with Amp 26716-01 and the Plantronics cordless  CS50, CS55 & CS70 were recommended in a thread in 2007 for the 7941 phones.  Is that still the recommendation in 2010 for the 7941 series phone???
maryclegg by Level 1
  • 471 Views
  • 2 replies
