IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5803 Views
  • 14 replies
Hi All,We are facing an issue in extension mobility/h323 gateway. The callers are getting continuous beep when the user is log-out state(users having DID)This is only happening when calling from extrenally. internally it is fine, give busy tone. Any ...
Dear experts.I have (at location A) voice PRI (from local telco) terminating on a modem. That modem is in turn connected to E1 controller in router 2821. This router 2821 is connected via Fiber link to my another router 3845 (different location B). F...
Jonn cos by Level 4
  • 588 Views
  • 6 replies
Hi!I have boot problem on two cisco 7906 ip phone.when i plug the network cable from my PoE switch, the phone power on and it's light stay on "applications menu" button, the screen is blank and nothing happened. I press and maintain # when power on t...
Hello,We are using CUCM7.0  with tcl script to play announcements, PSTN caller calls and dials CUCM extension to reach a IP phone user.The  problem is if the user dials another outside PSTN number while announcement is being played the outgoing dial-...
oterrones by Level 1
  • 342 Views
  • 1 replies
Hello All,I live outside the U.S. and need help making route patterns in CUCM7.   I have all inside network IP phones working and the gateway is setup and being controlled by MGCP.  The gateway is a 3725 with 4FXO mod supporting 4 analog lines out to...
Hi to all,I have one issue, the customer need to configure the radius in the voice gateway (router 2821) and enter the following command,aaa new-modelaaa authentication dot1x default group radiusaaa authorization network default group radiusaaa sessi...
Hey Guys,Can someone point me in the right direction on where I can find documentation on how many phones each platform can handle or how many mailboxes for Unity/Unity connection, etc...  I just want to make sure I get the right ones.  Thanks in adv...
