IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6584 Views
  • 14 replies
I have a customer who is attempting an upgrade from 5.1.2 to 5.1.3(g)when attempting ane error "Errors Encountered - Mount Failed"He has also tried 5.1.3(f) which is the same. Looking at the software it should be good to go from 5.0.4.Any helpThanks
Hi,we are using CUCM 7.0 and 2 no's of 3845 router as voice gateways. both the gateways are configured as mgcp GW.the requirement is, in srst mode if one GW fails calls should be processed through another VGW. is there any possibility to chieve this ...
baskaranm by Level 1
  • 612 Views
  • 2 replies
I am running 2 clusters, CM 4.1.3 and CM 6.1.2, I am trying to set the Directory URL for the phones on the 4x cluster to point to the URL of the 6x cluster which is AD integrated.I can get the 6x URL to work via a Phone service, but it doesnt work as...
cbednare by Level 1
  • 277 Views
  • 1 replies
I have a CME with voip dial-peers to a 2600 router. The 2600 has a frame-relay wan connectivity with vofr dial-peers to the far-end. Not sure if the 2600 will complete the call end-to-end going from voip h323 dial-peer to a vofr dial-peer. The far-...
grnelis by Level 1
  • 559 Views
  • 3 replies
