IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6134 Views
  • 14 replies
Hi All, we have 3845 ISR router with 4 full PRI. I need to configure MTP in the router to support incoming fax support to communicate with Microsoft Exchage to receive fax. there are one PVDM2-48 and one PVDM2-96 installed on the router. so (112-96=1...
Dear networkers,We have CUCM 6.0.1.2000-3 installed at the customer site.When trying to purge manually the CDR database, we have the following message : "Reloadproccess is running.Please wait till the Reload Process is over". (see attached screen sho...
Hi,We are trying to get a fax server solution working between CUCM and our SIP provider but it seems the fax server only supports T.38 and the provider only supports G711alaw.Fax Server (t.38) <-SIP TRUNK-> CUCM 6.1.3 <-SIP TRUNK-> Service provider (...
Hi,We are using CME 7.0 with IOS 124-24.T1 runnning in 2851 , we are having 7962 and 7942 phones along with CIPC but everday we are facing the problem of CIPC state Deceased for some phones only (all of the MAC is added already) we need to reload the...
Hi All,I've inherited a few older 7960 SIP phones and I am in the process of converting them to SCCP for our CUCM 7.Unfortunately some of these phones are password protected and I can't unlock them.I really want to factory default them first.The proc...
phonetech by Level 1
  • 2702 Views
  • 12 replies
