IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5644 Views
  • 14 replies
Dear Friends,I'm facing an issue, when I dial the DID of the call centre and trying to insert # as input (as menu ask to insert # to repeat the menu) I got message (which uploaded in case of customer time out without input) telling plz insert choice,...
It says you can create a software MTP on The voice gateway. I have looked everywhere for the required config on the 2800 Gateway, but no joy.I have seen plenty of examples to configure the MTP on callmanager.I am wondering what commands are needed on...
pcromwell by Level 3
  • 1358 Views
  • 1 replies
CME
Hi netpro'sI need to run my configuration past you and ask the following questions:(I am running CME7 on a 1861 router with 2 built in ISDN BRI's)1 - When I connect my two BRI interfaces to the ISDN TA it stops me from sending and receiving calls. If...
Resolved! BRI info
Hi How can I check how many active channels are being seen on my BRI interface.BT have configured 1 ISDN BRI circuit with 4 channels configured on it and only 2 of the channels are working.I told BT i need 2 physical circuits and they said I didn't ?...
I have a UC520 system that is using a SIP trunk. There is an ISDN for local break out. Everything works fine except for calls that come in via the SIP trunk which then get forwarded back out of the SIP trunk. The call setup works but when the forw...
