IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5599 Views
  • 14 replies
Resolved! Phone Call History
I usually don't post, but I have a customer asking me a question that I can't find an answer to.The customer has 7962 phones, and is asking a 2 part question; can the call history size be increased, and if so what the upper limit is.Any help would be...
I was wondering if I could get everyone's opinion on the advantages of using a full deployment of Extension mobility vs a full deployment of hard phones. Our company has been rolling out each of its sites as EM. However I do not believe everything ne...
dvanzee by Level 2
  • 349 Views
  • 3 replies
Resolved! Localization
How do you add a new locale to CallManager 4.3? I have been reading about something called a Locale Installer plug-in, but I can't find it anywhere, all links on the Cisco website are not taking me to it, and the only one that seems to be available ...
refram by Level 3
  • 336 Views
  • 2 replies
Hi to all, I have a UC520 I configure a AA script at the end of the script I need to tranfer the incoming call directly to a VM of a user, so I follow this guide http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00802ab979...
a.crippa by Level 1
  • 429 Views
  • 3 replies
Hi,I did the following configuration:hostname Routerip domain name infomicro.localip name-server 192.168.0.100fax receive called-subscriber $d$fax interface-type fax-mailmta send server 192.168.0.100 port 25mta send subject "Cisco FAX to Mail"mta sen...
Hey Guys,I am having some problems with SIP trunks going to a Motorola device. Are there any debug commands I can use to check the status of my sip trunk or any other trouble shooting tools I can use to get through this problem. Thanks for your hel...
