IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5959 Views
  • 14 replies
Hi all,we're experiencing an annoying problem with Cisco UCM 6.1 (version 6.1.2.1000-13).The problem is that now and then call transfer function stops working - you press the softkey and no result follows. Can be cured by restarting CallManager servi...
v_bashaev by Level 1
  • 965 Views
  • 6 replies
hi does anyone know what's the difference between these two pvdm modules:1. PVDM2-16U48: PVDM2 16-channel to 48-channel factory upgrade2. PVDM2-48: 48-Channel Packet Voice/Fax DSP Modulei'm trying to figure out what's the difference can any body help...
Hi all, I would like to ask about call processing. I have my phone in DP which got CUCM group adjusted that 1-Subscriber 2-Publisher. Route patern Im calling through got route list of two GWs and route list is in the same CUCM group (1st-Sub 2nd-Pub)...
Hi,I'm trying to get file accounting working on 2800 router running 12.4(20)T.I can see the messages in the debug but there seems to be an issue dumping to the remote file in ftp.Error - *Apr 9 17:31:27.191: %VOICE_FILE_ACCT-3-DUMPFAIL: Could not du...
Hi,I have 2 analog phones connected to a 2600XM router, i have added the router as a h.323 gateway in call manager and i can call the analog phones from a ip phone, however the is no sound from the speaker on the ip phone. (the ip phone works when i...
We upgraded from CM4.2 to CM7.0(2) and we're now looking at Attendant Consoles, and directories in general. We're in the middle of developing an online campus directory. If we can create a CM specific LDAP - will the Attendant Console Corporate Dir...
