IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5717 Views
  • 14 replies
Hi Pros, Ireally need help with this project.Tere is the thing, we are using a t1 trough an Altiagent server now, everything is fine.Now we need to upgrade the Altiagent without any downtime.We are thinking to add a cisco router to replace the...
Hi, The E1 connection will "sometimes' freeze for no obvious reason. Once a month, then maybe 2 times a week, then nothing for 2 months. There is no pattern in this freezes. I have configured everything correct. I have used this setup with the same p...
Hi, I tried to configure a cluster in a CCM version 6.1.3 using wizard option, it ask for the publisher name, Ip address and the the security password but it does not work, at the end of the procedure an error was displayed, is there an other way to ...
carlosg by Level 1
  • 249 Views
  • 1 replies
