IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5886 Views
  • 14 replies
Trying to register a new Conf bridge with CM 6.1 and it shows Registration "Rejected". Here is the GW config. Ideas?sccp local Loopback0sccp ccm 10.224.13.12 identifier 2 sccp ccm 10.224.13.11 identifier 1 sccp!sccp ccm group 1 bind interface Loopba...
dvanzee by Level 2
  • 469 Views
  • 2 replies
I have a T1-PRI tie line between the PBX(Avaya G3) and my Call Manager 5.1 w/2811 voice gateway. The issue is getting the caller-id to work on calls coming from the Avaya. The company that handles the Avaya says they are sending the Caller-Id but all...
sdeal by Level 1
  • 1523 Views
  • 7 replies
Here is what I get in the event log. Unable to read the disk performance information from the system. Disk performance counters must be enabled for at least one physical disk or logical volume in order for these counters to appear. Disk performance...
julienf28 by Level 1
  • 356 Views
  • 1 replies
HelloI need to block some outgoing call destinations placed from an specific ephone *only*. Which would be the best way to do this? We're running CCME 7.0 w/ CUE 3.2.Any tips will be apreciated.Thanks in advice.Guilherme
guilherme by Level 1
  • 370 Views
  • 3 replies
