IP Telephony and Phones
Labels
We have a customer with cisco call manager express. we ahve a 4 port fxs card with a fax machine on this.outgoing fax works no problem, if you send a fax to the fax machine from over the service provider the fax machine answers connects but lets say ...
Resolved! Directory numbers
Pls do somebody know, how to inteligently edit (for example delete more of them) directory numbers on CCM 4.2, I found possibility how to reach it on CCM 5 and 6 on Cisco pages. But I got CCM 4.2 and I cannot find it there in menus. Thx
Hi,We are using Cisco Call Manger.Now we have another office in singapore which is connected by L2L VPN.In singapore they are having there own call manager.Now the issue is from my office I can able to call them.But they can't.In my call manger I hav...
somnath21 by Level 1
  • 313 Views
  • 1 replies
Hi,I am using ccm 4.1.3 and we have auro registration configured and working. But the issue is when al the numbers have been used, the next phone gets an "Error DBConfig" The phone will not look at the start of the range. It just errors out and we ha...
rcrumm_2 by Level 2
  • 1076 Views
  • 6 replies
Hi!I have a CCM 4.3 (upgrade from 3.3). I have a very strange problem - I can't register any MGCP device. When I try to configure installed module (E1 card in slot 0, for example), I got erron on CCM's page (on the bottom of explorer page):Script err...
paa by Level 1
  • 687 Views
  • 5 replies
Hi all,I'm using CUCM 6.1.2 with IPMA feature.For Directory search, we are using a third party directory server, not a CallManagger Directory.From the IPMA Console, I would like to force the Directory search to use the third party server and d not th...
a.namnami by Level 1
  • 505 Views
  • 2 replies
HelloI noticed that with CCME and Extension Mobility that it doesn't cache the last username that logged in to an IP phone?Where as with real Call Manager it does.Does anyone know how to cache the last user to login into EM on ccme phones?cheerskarl
Hi,I have an issue regarding toll bypass.I have 2 clusters: Cluster 1 and Cluster 2.Sites that are on Cluster 1 are:A,B,C andon Cluster 2 are X,Y,Z. Both the cluster are communication through intercluster trunk.What I want to do is to make a PSTN cal...
