Resolved! Callmanager 4.1 issue
Hi all, recently i faced so probs with CCM 4.1 to register an IP Phone 7911 i got DBConfig Error but i with a 7970 it was fine so does this thing related to the fact that 7911G is not listed on CCM 4.1
How to configure the fxs port which will be used for connection to the fax machine? And how to configure a dial peer fot that?
Can someone help me out. I know that the 5184 and 3155 dial peer we are using for fax fxs cards. I don't know what the other Dial peers are for. And I want to clean them up. We just moved to a new location and we just got a PRI. D
Hi there,I got a question about Attendant Console (AC) Hunt Group and Pilot Point. Once or twice a month it stops working and then I have to Reset the AC Hunt Group by following the procedure below:? stop CTI manager service ? stop TCD service ? Del...
Hi,I am building a CCM 5.0.4 server on a HP DL380, at the end of the initial build it fails at - "security configuration fails(1)"The server is the first server in the cluster and is connected to a 3550-24POE switch for it's FA ports on the server.Ha...
What is the mx number of hunt groups possible in UCM 6.1 and what is the max no of lines in each group ?
Recently I have been tapped to administer our SMB VOIP system utilizing CCM 4.2 and Unity and 7900 series phones.I have no VOIP experience but am up to the challenge any suggestions on where I should begin obtaining knowledge to enable me to administ...
Hi,I have set up a small LAB for IPIPGW, i can go through it with G711 but when i begin to manipulate the codec, like using using G729 it does not work.what i need to do:1) CCM 1 (G711) IPIPGW (G729) CCM2; I have transcoding for CCM1, CCM2 and for th...
Hello, installed AIM-CUE with 2.3.4 into 2691 with CME.- From the router's CLI I can ping CUE. - From the CUE's CLI I can ping router and all of the local LAN.- I can access the CUE's web GUI from the LAN without any problem.- I CAN'T ping any intern...
I have CME on 2811 router.I tried to create dspfarm profile conference but in maximum session i got 0 maximum sessionsAny others profiles ( mtp,transcoding) i got maximum sessions as much as dsp i haveI have PVDM2-16 channels
I have heard the call can be recorded without configuration of SPAN in callmanager 6.0, anyone can give me more detail about this feature in CCM6, and how to configure this feature.Thanks
Hi,CME voice gateway 2811 has VIC-4FXS/DID configured as DID trunk. The local teleco said they send us 4 digits, however,we only received the first digit instead of 4-digit for inbound DID calls.IOS version is 12.4(15)T3.signal type is wink-start.Can...
Hello all,I am getting an RTMT alert about our CDR Repository not being backed up. I am wondering though, we have recently began off-loading the CDR to a 3rd party billing application, would this be the cause of what I am seeing here? If so would th...
Hello, I have a UC520 with 2 analog lines going in and about 10 users with 7941s and 7912s. On their old PBX system they had 2 little red lights on each phone that lit-up whenever a line was busy.Now, there doesnt seem to be a way to display if their...
I am running CCM 4.2. I have a facility that uses a 2820 (h323) for outbound cals through a T1. When calls are placed, the router sees the call but it takes 10 seconds before the call rings out. During this time the IP phone says "call proceed. This ...
Subject | Author | Posted |
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM | ||
01-16-2023 10:22 AM |
User | Count |
8 | |
7 | |
4 | |
4 | |
1 |
