IP Telephony and Phones
Labels
I am trying to get a CM 5.1 box setup in our lab. The server came with the CM software installed and the first time it started up it automatically started the Kudzu program but the server lost power while it was running and now Kudzu is not starting ...
jmaduncan by Level 1
  • 464 Views
  • 6 replies
Hi,I am having Call Manager version 4.2(3). I am having a H323 trunk to one of my gateway. I am having 1024 kbps bandwidth for this link towards this gateway.I want to reserve 512 kbps of bandwidth for my incoming calls through this gateway. How can ...
dumble4me by Level 1
  • 477 Views
  • 2 replies
If the dialpeer have the same preference, this case is default 0. Does that mean the call will be distributed to the two ccms in round robin fashion, meaning one call to ccm1, the other call to ccm2? or the 2nd dial-peer will never used? or the call...
I have a few 7960's that refuse to get an IP address. Even if I configure the 7960 with a static IP address it still does not communicate with callmanager. I've plugged in a known good 7960 into the switch port and it works fine. Everything seems ...
jones2sr by Level 1
  • 1017 Views
  • 7 replies
Hello,I have a problem found on 2 routers , they are c2800 with FXS ports ( VIC2-2FXS) , problem that when I connect the phone to port 0 , the 2 fxs ports become off-hook , even if the phone is on-hook , and I can't dial to these ports as they are bu...
