IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6166 Views
  • 14 replies
hi,i have installed the CCM 5.1, the problem is once in the while when i reboot the CCM, and i try to logout the phone, the message : "Device EM not Enabled", and i cannot logout the profile neither from the phone nor directly from call manager.pleas...
dbenattou by Level 1
  • 365 Views
  • 2 replies
I have a config issue with ucx 1.21. My issue is that when someone calls into ucx auto attendant and either 4 digit transfers to an ip extension or selects a user out of a directory handler the call is a supervised transfer to the ip phone. The cli...
dnelson by Level 1
  • 272 Views
  • 1 replies
I have two ipcc express (4.04) servers configured in fail over. on one of the servers I can see a red cross over the desktop chat service. in service manager the service has started but appadmin says other wise (see attached screen shot) any one seen...
Resolved! What is it called
I can't think of what it is called..My company wants to put text messages on our phones (7940/7960), in case of outages, or even to wish everyone a happy holidays! What is that called? System Message? Event message?Thanks
Dear Experts,I had Cisco 2821(CCME) and Panasonic TDA-200 connected by E1. Calls correctly processed, but CallerID is not transfering through E1.My configs and debugs:mos2821v#sh isdn status Global ISDN Switchtype = primary-net5ISDN Serial0/0/0:15 in...
I one CM version 4.1 and a 3745 gateway connected to PRI ISDN E1.Output calls to PSTN works fine.Problem is when one input call comes throught PRI-ISDN.Local PTT send four digits that I can use to route call to one internal extensions. However number...
j.ceron by Level 1
  • 371 Views
  • 3 replies
