IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5564 Views
  • 14 replies
I'm having a heck of a time getting my IP Communicator to register over a VPN. It registers in the wink of an eye if I'm in the building, but if I go outside, not so much. I am using IP Communicator 2.0.2.0, the Cisco VPN client 4.0.1 and I'm conne...
refram by Level 3
  • 506 Views
  • 3 replies
I have a issue and was wondering if some in the post have a workaround.A remote site that invokes AAR has problems when the press the message button. They get the general greeting.Is there way to fix this without going to every sub account in unity a...
jgittins1 by Level 1
  • 306 Views
  • 1 replies
Hello:I'd like to use the AAR feature to have incoming DID calls to remote site phones set for fwd'd bsy/na to vm, to use the pstn when the wan link is down or out of bw.the site will have a pub 4.2, and unity 4.2 at central and a sub at remote. metr...
rvincent by Level 1
  • 289 Views
  • 2 replies
Hello,I have a C7940G in SIP firmware POS3-08-6-00.I need to regularly check the RTP counters by telnetting to it and do "sh rtp".But I need a way to reset these counters.Clear RTP doen't exist so the only way I found was to reset the phone ; which i...
kwillocx by Level 1
  • 529 Views
  • 2 replies
Hi,I have a CME system and trying to get the company logo Up on the LCD when phone is idle. What format must the image be in, and what tools can i use to edit the image. If there is a document that shows how to do this, it will be helpfull. Thank you
p.holley by Level 1
  • 312 Views
  • 1 replies
