IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5956 Views
  • 14 replies
We try to use IP Communicator 2.1 with the Unified PhoneProxy. IPC needs a very long time for registering. We have seen that it tries to connect serveral time to the CallManager (version 4.2) using port 6970/tcp. This port is new an used for centrali...
pwenger by Level 3
  • 239 Views
  • 1 replies
what's difference between the two part number? looks the first one is bundle to hardware and the 2nd for additional.LIC-CM5.1-7815=(License CallMgr 5.1 7815 Appliance, 500 seats)LIC-CM-DL-500=(CallManager Device License - 500 units)Thanks in advance,
cjrchoi11 by Level 1
  • 532 Views
  • 8 replies
When trying to bind SCCP i get the following debug error on the gateway:Jun 14 2007 16:34:56.596 UTC: sccp_parse_control_msg: rcvd register rej, reason: Max Phones ExceededWhat does this mean exactly?
wfeng by Level 1
  • 701 Views
  • 1 replies
