IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5822 Views
  • 14 replies
Hi allWe run a Callmanager 4.2(3).When I install the local files (German / French / Italien) I basically don'tneed to install the Network Local File?Ist that true?Thanks for helpReto
telefonie by Level 5
  • 456 Views
  • 1 replies
I would like to know whether AAR is used to reroute the calls through PSTN if WAN is congested or even if WAN link fails ? Because I have a centralized CCM running at HO,and Branch with SRST enabled. I guess translation pattern might help me at rem...
Hi,we plan to build a cluster that will support multiple customers from our site. For ease of use, can call manager accounts be setup that will enable customers to manage (add, move, change etc) their own phones & route patterns etc.thanks
following error comes on CSS which we are using for load balancing of media files please explain these errors."JUN 6 22:59:11 1/1 11895965 IPV4-4: Ipv4MasterForwIphdrChk: Dest = 224.0.0.18, Src = 172.17.50.38, DosAttack ILLE...
