Resolved! SPA8000 UC560
Hi good morningCan I use 2 or 3 SPA8000 to get analog extensions with a UC560?We need to connect 20 extensions ..regards
If the UC320 is using automated scheduling, how can a local user take the unit out of 'night mode' if they want to open before the normally scheduled time? Example: Schedule set for "day mode" from 9:00 to 5:00 M-F. They have need to open at 8:00 ...
Hi good morning Can I use 2 or 3 SPA8000 to get analog extensions with a UC560? We need to connect 20 extensions .. regards
A reviewer on Amazon stated the following:" In theory the 320w can support both SIP and analog lines, with one big limitation. BOTH SIP AND ANALOG LINES MUST SUPPORT 10 DIGIT DIALING, EVEN FOR LOCAL CALLS. Analog and SIP lines must use the same dial ...
I have the Cisco SPA 525g2 phones and when the phones are on 7.4.9 firmware they connect to my ASA just fine. Once i upgraded to the 7.5.1a firmware i get an authentication group error. The ASA 5510 is running 8.2 firmware and i tried updat...
Здравствуйте. Мы надеемся у вас есть тех.поддержка знающая русский язык. Если нет то мы постараемся объяснить суть проблемы на английском.Суть проблемы в следующем.Мы используем для связи ip телефон Linksys spa941Serial Number 4KM00JB08837 Software V...
I jave read past posts that say the feature would be available by the middle of the year can anyone tell me if the system will now support remote extensions/teleworkers?
Hi, I'm using a UC560 and configured jabber for some iPhones. To avoid confusion, I moved the old numbers from the employees' desk phones to their new Jabber devices and assigned new dn's to the desk phones. So when someone is calling an employee tha...
Hello:I am thinking of purchasing the UC320 for my wife's small law office. In my day job, I'm a software engineer, but by night I'm their IT support. I have attempted to build a freeswitch system from scratch, but have only been partially successf...
Running UC320 with latest firmware. Data and Voice LAN run fine.Question is if there is any way to have customer remain on-hold and listen to music rather than ringing for 5-10 minutes.I am trying to confirm if there is any configuration possible to ...
Hi all,I have a client with a UC320 who wants to connect 2 polycom devices. Is there a (low cost) analogue to sip adapter for the UC320? I recall going to a cisco presentation saying they were bringing out a new analogue to sip adapter for the UC320 ...
Hello,Could someone explain to me how I can use IMAP and Googles SMTP server to use voicemail to email ?IMAP service is enabled and configured, but it is not workingI think google uses ports 465 or 587.Is there a way to trouble this to narrow ...
Hello,Does anyone have any suggestions on how to fix CUE AA not accepting user impput after a crash ?DTMF is configured.
I recently purchased a Cisco SPA525G2 IP phone but it continuously reboots when connected to my network either via WiFi or a wired connection. The phone will then lock up and the Mute button will illuminate solid red after about the third reboot. I...
