Is it possible to put the SPA8000 in bridge mode? I have it behind a firewall and it is not working do to the double nat.
We have been using the SPA502/504 phones on Broadsoft and Asterisk. When using the 500S sidecar on firmware 7.4.8 the blind transfer works. Process is: when on a live call press the bxfer softkey then press the BLF key on the sidecar and the call t...
Hi There,We have setup a BACD for a client, and the busy prompt is a very American defaul sorry all our agents are busy one.The client doesnt want this or like it.How can we change the prompt using CCA or other SBC support supported tools?Alternative...
Hi, I finally registered for an account, to ask this question, before I buy the SPA8800.I am wondring if it is possible with the SPA8800 to forward/redirect calls from one of the PSTN lines to a mobile phone or another land-line outside the office. A...
Hi,I need a suggestion about a choice for a solution that I've to provide to one of my customer. They needs a complete solution of Unified Communications. Their needs/specs are:1) Three sites connected through a VPN connection (or MPLS, this choice d...
Hi i have managed to set up a small voip system for a charity i volunteer for.This includes a spa8000, spa9000 and 8 networked BT home phones.All works well as we need it to but i am unable to transfer incoming external calls to another internal exte...
I have a couple of users working offsite; is there a way they can dial in and access their voicemail? I cannot find anything about this in the user or admin documentation. Thanks.
I have a customer that is moving from an older CCM v4.1 system to a new UC560. Currently, they have a pretty extensive corporate directory (more than 500 contacts). I realize that the UC560 doesn't integrate with AD, so the directory will essential...
Hi all,I've got a mixture of 504 and 501 sets connected to our UC 560. We've been running for about 2 months now, and I've seen this happen twice. More or less, all of our phones will reboot themselves. I haven't actually heard any complaints from us...
I've been fielding a bunch of questions regarding the UC320 over the past few days and this one keeps cropping up.Is there any plan to support pulling a URL in for music on hold? There are the two options of line in and internal, but I have had three...
I have a customer with a UC520 that has two analog lines in. Frequently both lines are in use and they are missing calls. I suggested it might be time to add another line. They called the Telco and someone told them that they don't need another line ...
Hello Everyone. I have a question on blast groups in a multisite environment with the 8.2 software pack. In this environment, a call come into Site B and is routed intersite to a blast group in Site A. This works - all phones ring as expected. T...
I have had 3102 for two years now, and has been using SIP connection all the time with no problems.Today I tried to add PSTN that is provided by Comcast ARRIS modem. SPA won't detect line as active. I implemented dialing rules and am getting busy t...
Hello, I want create a custom script for the AA. In this script i create a variabele with de caller id, now i want to create a if statement that looks only to the first digits of the number (the international number). How can i create a working condi...
I have not found anything but today ran into something I haven't seen before. I had phones setup in the 200-245 range that were working fine and then placed some analog FXS ports from 255-258 as fax ports. I could not get them to ring, they rang bu...
